| Posted: February 8, 2007 6:42 pm | ||||
Nice uberzev. You could almost make another one with this also. Put some hammer-head
marks and it could be smashed tiles. Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: February 8, 2007 7:11 pm | ||||
oh, that's very good, uber! well done!
| Posted: February 9, 2007 1:21 am | ||||
| Posted: February 9, 2007 1:37 am | ||||
| voldemort |
Brialliant --I can see alot of texture makers liking this one
Is it a single color tile or do you have multiple colors and patterns The only thing I would say is Looking at the grout it looks higher up in some areas then the actual tile you might try shading the grout height map a little darker to offset that The lat thing I would say is If you could leave some chunks in the voids and actual fragments ""on top "" of the existent tile it would add to the realism Again only reason I say this Is because I know you could pull it off otherwise I would keep my big mouth shut Last but not least P L E A S E release some of thees like the rock pile and this Boy would I ever love to disect them to see how you pulled off the rock pile Your work Is fantastic one last time Please come on its something when He who should not be named beggs like a child ![]() lets all whine for a wine port |
| Posted: February 9, 2007 8:37 am | ||||
| jffe |
Nice depth, although not sure why the insulation or whatever behind the tile is gray like that, looks kinda scary ha-ha.
jffe Filter Forger |
| Posted: February 9, 2007 3:05 pm | ||||
Hey Uberzev, at first glance, maybe make it grooved like it looks before the tiles are placed. Also, maybe dark holes with peices of plaster and wood around the edges like a demo hammer just went through it....
| Posted: February 16, 2007 12:10 pm | ||||
uber, why not release it? looks pretty damn good to me. normally, when you see this kind of texture, you dont see the depth around the cracks and stuff, so i find yours pretty impressive.
| Posted: February 16, 2007 1:00 pm | ||||
Torley
Posts: 303 |
When I think of smashed-up delicateness, I think of porcelain.
Looks more convincing to me than what I've seen with some other plugins, e.g., Alien Skin's Shatter. Nice work with grit! I'm enjoying using Filter Forge to create http://torley.com/textures |
| Posted: February 19, 2007 5:53 am | ||||
Ok, since I never get around to finishing anything if someone wants to take what I've started here and run with it that would be great.
Busted.ffxml |
| Posted: February 26, 2007 4:25 pm | ||||
I like very much the crackles and destruction of the tiles, it looks very realistic.
I have made one with a color texture overlay, although it does not look the same well done as the white above and I must make that the texture is ONLY applied to the not broken tiles part and not to the whole image. |
| Posted: May 3, 2012 2:17 am | ||||
Nice grungy look SpaceRay!
How'd you do it? |
| Posted: May 3, 2012 9:02 am | ||||
I only added a Blend mode component at the end and mixed the source with a grungy green texture I have and adjusted the opacity and used the hard light blend mode (I think, not exactly sure) BUT this is not really the good way because ALL is green and the great destructive effect of uberzev is lost in my opinion. |
| Posted: May 3, 2012 9:35 am | ||||
| Posted: May 6, 2012 4:20 am | ||||
| Posted: May 6, 2012 4:31 am | ||||
Go ahead and upload if you like. Just know that I'm entitled to royalties. |
| Posted: May 6, 2012 4:49 am | ||||
Can I submit it to the library, or do you want it here?
Don't worry, you'll get 100% of the mony I make off this filter |
| Posted: May 6, 2012 5:56 am | ||||
Do what you want with it. I'm cool.
| Posted: May 6, 2012 3:03 pm | ||||
Very well done. Thanks very much for doing this. I was going to think how to do it but as you have already done it and very well, I do not have to. I have to say that what I have made above was a very quick test and knew that I should find a way to add the image source in another different place of the filter than at the end if I wanted to keep the destruction texture outside of the image source, because of course that at the end the effect is done over ALL the image on not just in parts. Thanks to you again for making this and also of course thanks to uberzev that is the master and creator of this filter. |
| Posted: May 8, 2012 12:57 am | ||||
I have another possible idea, and is the feature, option and ability to change the well done grey cement wall behind the tiles for your own images, so it could be like the "tiles" that makes this side of the universe is breaking down and shows in the back another different universe or dimension
| Posted: May 8, 2012 5:57 pm | ||||
Right now you can control the color\image of the tiles, and the color of the cement (and how rough it is.
I made this filter with FF2.0, so there's no multi-image support. I can upload a new version for FF3.0 which will allow for 2 different images. |
| Posted: May 8, 2012 6:08 pm | ||||
33,849 Registered Users
+10 new in 30 days!
15,392 Topics
12 unregistered users.
