I have been trying to make a filter that could simulate in some way this text effect, although obviously it would not be the same as FF still does not supports text, BUT there is some text fonts made by ThreeDee, see later.
I have seen this image shown here from the cover of the book "Let the Devil Sleep" by John Verdon, this is the Spanish version of the book cover published.
and here you can see the eye behind and the text in more detail
As said I can´t make in FF a text as thick and big as this and can´t make full phrases and repeat them as is shown here and in 2 different sizes.
BUT thanks to the great, very well done and amazing work of ThreeDee with TD Europa Sans Caps Proc Font Advanced by ThreeDee
I have made a new filter that makes this much basic and simple pattern filled with 5 letters that you can choose easily with a slider from 25 available in 5 groups.
FF Lifesaver
And using a solid color fill texture instead of a photo filling
The Numbers Game by CFandM
Is possible and probably that before you have already seen something similar with the already available filter The Numbers Game by CFandM
BUT this filter I am making has no relation with this filter (it is not based on this filter) and it does NOT need any external source image to make it work as it happens with the CFandM´s filter.
And also that this filter was made for numbers, and this one is for letters.
Here is my own conversion with letters from inside FF instead of external numbers
Here is big version of the letters that give this possible result
