Messages 1 - 45 of 48
Art In the Round by CFandM
http://filterforge.com/filters/10560.html
Wow! I did not value it enough when you have put the previews in another thread, I though that they were just simple plain drawings, BUT I am happy that I was totally wrong.
These are really beautiful, elegant and stylish art maker, and is much more than I could imaging it could be, and now that I have seen it working I think it has a lot of possible uses and it makes LOTS of creative shapes and with many variations.
Nicely done and good idea.
Thanks very much.
Just one question, that I do not know, Please, would it be possible to have the brown big circle shown in the thumbnail above and the one below here be able to be fitted completely inside the frame square?
Nice CFandM ! Well I'll be glad if you create some more like this one. smile:)
I have one suggestion and this offers MUCH more than you can see in the thumbnail, so I want to suggest that if you want, you could put more presets that could show much more the great flexibility and power of this filter. Perhaps you did not do it because you like more to put simple and more elegant shapes and drawings art, but I think that some could be missing parts of it.
Also from my own point of view and personal opinion I would recommend to change the first main preset as this offers much more than is shown on the first master thumbnail and is it very plain compared to what can be done, but this of course as said what I personally think.
another example
one more in the art deco style
another variation from the same preset
one even more complex
and beautiful and artistic lines
I have to say that filters like this one is what really marks the difference to any other software that you could find and makes filter forge shine much.
And this nice and elegant design here could be used very well as a frame for another images
and another preset with different settings
All this could be a great source for shapes to be:
filled with images INSIDE the those shapes too,
or fill them with textures,
or use them as mask overlays
and other more possible uses
This filter is a wonder LOL
Another different pattern
SpaceRay Wrote..
I can update it with that function.. smile;) smile:)
SpaceRay Wrote..
Well I was saving that for the other version Vector in the Round... smile;) smile:D Submitted that one today..
CFandM, it would be great to be able to get an alpha bg.
And this
Then one more from Vector in the Round...
Ghislaine Wrote..
Yep sure am.. smile:) smile:D
Another one
Here this one
I have to much fun with this filter... as I love it
the last for now
ok now a last one LOL
One more
Ghislaine Wrote..
Well, ok.. smile:D I sent an update to this filter, should be up Tues...I sent the other filter also but have to wait on updating that one with the same options....Here a new update...
Then here is the alpha...To use it I have included a control where you can choose either no alpha..Just the circle or if you have the lines black it will use that as an alpha as well...
SpaceRay Wrote..
Yep updated that also...There is a control for that as well.. smile;) smile:D
Thanks very much for the update, I agree with Ghislaine that is good also to have to option of the alpha image background and is a good suggestion and idea.
Thanks also for having done the request of the circle to fit the square.
I have another example I have done in Photoshop, I have done the source with this filter and then loaded the texture in another layer and changed the blend mode to darken, and then made selection in the center to make a hole in the middle to show through also.
another
Gene S Morgan
Filters: 81
CFandM ... I have worn out my finger hitting the variations button on this one. Everybody has come up with cool examples but I really like what SpaceRay did on the last couple of images. There are lots of possibilities with this filter .. Nice work.
Gene S Morgan Wrote..
hehe.. smile:D Guess I should have put a warning in there... smile;) smile:)
SpaceRay and Ghislaine thanks for all the samples.. smile:)
Can we look forward for a third one ? smile:?:
Well I don't know about that Ghislaine smile;) ..I do like to make a couple of filters on certain methods but just change them a little...So I am using this filter for the next one but just change it a little...So this one will be sorta abstract faces... smile:D
Then one more...
Then one more with the new one...This one has Carls Thump filter applied. Then placed inside a frame from Used Frames... smile:)
Very good and nice works you have done in the last 3 examples, and like how have done the mix with Carls Thump filter and the frame added, it really is a good artwork that deserves to be framed.
NEW UPDATED VERSION
If I liked this filter much before, now with the new update it even much better, very good and very useful the new "circle size" option that gives much more flexibility and also you can zoom in and out the creations and customize it very well and much better than before.
Also very good idea to make an alpha mask mode leaving only the main circle and cut out the surroundings, and then mode 3 adding the deleting of the "lines" color and so all becomes transparent. well done.
And here is with Alpha mode 2
And Blend Mode 3 with transparent "line" color
And although this filter ONLY makes beautiful CIRCLE designs you do not have to use them AS CIRCLES ONLY.
I mean that you can save the result form this filter and then load the great Shapify by uberzev filter and convert this circles into OTHER SHAPES, so you have then "Art in the triangle", "Art in the square", "Art in the Hexagon" smile:D
Art in the square smile;)
And by only changing the Smoothness slider setting in the Shapify filter you get this curious different design
The new Circle size option is really useful and good and you can zoom in and out of the design and get much more options and go inside the circle searching for more shapes that are in the design but too small to be seen, it´s like a fractal that can you discover new things zooming inside the design.
After having seen the new updated version I have though of one possible and very easy to make suggestion if you want and like it.
Change the "Tiles" setting from "non allowed" to "Allowed" so you can load images instead of plain colors, this could open a much bigger possibilities.
here is another example. I would like to use the filter without modifying it so you can get the usage rank you deserve for making this really awesome filter, but would agree and understand it if you do not want to change this and only allow plain colors.
On this example and the one above the only this that has been changed is that now is allowed to use external images in the tiles setting.
And the last example of this modified with external images textures in the same preset and design
Here as in the other two, the only change is that I loaded an external texture in the "tiles" setting I have changed.
33,860 Registered Users
40 unregistered users.
