inujima
Spiral Gradient by Crapadilla
http://www.filterforge.com/filters/10128.html
inujima
I attempted to combine this snippets and Sixties Swirl filter. smile:D
The first update is in:
- Optimized AA zones generation.
- Enabled Seamless Tiling so the component can be used in seamless filters.
- Replaced all the Profile Presets with a single Curve Editor.
- Controls are now fully mappable (where possible).
Attempt successful! smile:beer: smile;) smile:D
Now to make this filter feature-complete, I'll need to find a way to shade the spiral gradient like this:
Fast Spiral by Sjeiti
James
James
Filters: 46
Great work, this type of gradient has many uses. smile:D
To-Do List:
- Fix script error for Size = 1.
- Implement a 'Fixed Size' option.
Argh! Forum gives me the red mysterious "Message Text" message, so I have to attach the whole filter instead.
I added some minor fixes and optimizations - I'm too lazy to go over them, so find a good free diff viewer smile:-) (notepad++ supports lua syntax and has a compare plugin smile:-))
Spiral Gradient - Sphinx.ffxml
That drill mode gradient is a good challenge smile:-)
right after
-- Convert spiral gradient map to 0...1 range
spiralGrd = spiralGrd - aa_zone
try adding
spiralGrd = (spiralGrd - radialCoordinate) / 4
now that "4" is just some quick normalization constant - I'm sure there is a more theoretically correct way to normalize the output.. its here inujima and ThreeDee comes in (where did he go btw?) smile:D
Update is incoming... Thank you Sphinx.
- log(0) error handling.
- Fixed Size option added.
I'm all for theoretically correct! smile;) smile:D
This filter made my day from gloomy to sunny.
nice mod inujima. smile8)
Double spiral madness smile8)
Orteil
but certainly
Filters: 51
That last one is oddly disturbing, in a Junji Ito kind of way.
Good stuff dilla....
Sphinx..wrote..Double spiral madness smile8)
Most likely a lot easier then my early filters before scripting... smile;) smile:)
Filter update:
I've ditched the LUA script implementation and constructed the gradient old-school (i.e. with native components), which renders about 6.5 times faster. The legacy LUA script will remain inside this filter for archival purposes.
Filters: 710
Nice update. smile;)
Very nice gradient tool. Will prove very useful in some of my projects. I like the "fractal" like quality of some of the results. I've already thought of an artwork that can use it.
33,846 Registered Users
+12 new in 30 days!
+257 new in year!
22 unregistered users.
