GF Kaleidoscope by Ghislaine
http://www.filterforge.com/filters/10049.html
WOW Ghislaine, Have you really made yourself this kind of filter ??? It seems you are learning a lot very fast.
This looks very interesting and could give very beautiful results.
I really love kaleidoscopic image effects and want to thank you very much for making this filter and will give you my comments later when I try it and see wht it can do.
Thanks again and continue making filters and learn more and more, you are going in the right way.
Hello SpaceRay smile:)
Thanks a lot for your kind words. Positive comments help filters authors to continue
create filters ans share them with the community.
Yes, I have created this filter. I was not sure to share it because there are a lot of kaleidoscope filters in library. But as said, I learn very fast because I practice a lot too. And finally, I find that creating filters is easy because we have the help menu and also we create in real time. So I try components one by one and can see in real time what is going on with all components.
I also love kaleidoscopic effets. Anyway, the best way to learn and progress is to try each component and practice. I also apply my own images on each filter that I create.
No time for now, but tomorrow I'll post few examples I made from this filter.
If you try this filter, I will appreciate to see few examples. smile;)
Well, I have tried your lovely filter and I must say that is among the best of the ones I have seen, I have only two others similar (although different) kaleidoscopic filters that I also like much. Yours is special and gives excellent results and very well done.
It now belongs to my favorites list
Ghislaine wrote:
Thanks a lot for your kind words. Positive comments help filters authors to continue create filters ans share them with the community.
Thanks to you for your skills to learn and make beautiful and useful filters like this and I encourage you to continue learning more and more and keep sharing your creations here.
OK here I put some examples for you
And what about some beautyfull Violet Gladiolus Flower with the GF touch smile:)
And this is with another preset
And now that comes the spring in the south part of the world I will put something more sunnier smile8) to lighten up a bit to all the ones that we have begun now the cold autumm smile:(
and this is the same above in more detail close up
What would happen if you take the head of a white sumatran tiger and put it through your wonderful GF filter ???
well it happens this smile:D you get a Kaleidoscopic tiger smile:D
Here is seen in more detail
I have some photos of clockwork close up mechanism and machinery and I have put it through your lovely GF filter and here is the beautiful and surprising result.
And if you want to look closer and in more detail here it is
and even more close up and larger
And this is not the only one I have made, I made another with a different preset that I like much too
And here is more closer detail
And to end for now, probabbly you have seen my photo of 2 parrots in others threads, well what happens when they enter into your GF filter ? I was really very surprised when I found that the result was this one here smile:eek:
Where have the whole body and head gone ? smile:D
What I have got is some beautiful and wonderful frames !!!! smile:)
And here is in more closer detail that you can only see the claws of the parrots
Is really surprising the results that you can get with this kind of kaleidoscopic filters smile:D
Don´t be afraid to try and experiment with some photos you may have !!
After all these I want to thank you again for the quality and great results you can get with your well done filter.
I forgot to put the original result that I had at the first that was not two frames, was four frames and here it is.
I am still surprised that from the 2 parrots photo you can get as result this kind of frames !!! Amazing smile:eek:
By the way ALL the examples have been done with all the normal presets offered by default from the filter, I have not changed any setting.
I love FF smile:loveff:
Thanks for your examples ! also cute and funny smile:) Yes this filter gives surprises.
I never saw a tiger or a parrot like this before and I found it very interesting.
This week I will create another kaleidoscope with more variations. This one was the first one but I jope that the second one will be different with more possibilities.
Here the first original image for starting my examples. I used the default present.
First example with this image
A second example
No 3
No 5
With another image
Example 1
Example 2
Third image
Example with this third image
33,846 Registered Users
+13 new in 30 days!
+13 new in 30 days!
+44 new in year!
