| Posted: July 10, 2014 6:08 am | ||||
Very nice filter with a lot of presets!!
| Posted: July 10, 2014 6:09 am | ||||
EAdams
Posts: 447 |
Beautiful filter!
| Posted: July 10, 2014 5:21 pm | ||||
| ddaydreams |
I really like this filter, it's a lot faster than the old one.
I like the line size control which at lower settings makes an outline which seems to ad some punch. I ran across something odd, it looks like barcode artifacts in the background. I would like to keep the nice outline but loose the barcode. Any thoughts? |
| Posted: July 13, 2014 11:17 am | ||||
Thanks for noticing this. I had seen the "artifacts" before but only realized how to fix it today.
There is digital clipping in to the last high pass component in the diffusion section, it is set to 100% contrast. I fixed it by changing the contrast to 99.9%. Did a little testing, not quite ready to post the update, but I'll attach the filter with the usual warnings, this is an beta version of the filter, blah, blah, blah. I should have the update out this week. Derivative Diffusion clipping fix.ffxml Math meets art meets psychedelia. |
| Posted: July 13, 2014 6:34 pm | ||||
| Posted: July 13, 2014 7:23 pm | ||||
Very sweet!
Bet if you iterate that entire filter it'll go mad crazy |
| Posted: July 13, 2014 7:30 pm | ||||
All I can say is
| Posted: July 13, 2014 7:53 pm | ||||
| ddaydreams |
Thanks Rick That fixed it for me.
As far what you said "Odd thing, though, it appears that an image created on my system does not match yours using the same parameters as listed" Are you sure your variation set 14790 ? |
| Posted: July 13, 2014 8:54 pm | ||||
Wow! This looks very good and very well, regetably I do not have time to try it but surely will do whenever I can.
Well done and thanks very much for making a filter with this very cool and interesting topic |
| Posted: July 13, 2014 10:59 pm | ||||
Thanks all. Frank: images are the same, missed the Line Angle Adjust, my bad
Thanks for the critique. It helped push this filter along. Sometimes I need an editor Math meets art meets psychedelia. |
| Posted: July 14, 2014 12:35 pm | ||||
Could go like at least 20 iterations before showing signs of something more life-like really.
Uberzev's more responsible for starting me up on the whole thing. haha. Would have not bothered to deal with it without seeing some example pictures first. |
| Posted: July 14, 2014 1:18 pm | ||||
I tried a version on my fast machine with more passes. The original is 4.5 iterative passes. I tried one with 12.5 passes, and one with 16.5. The 4.5 & 12.5 version are posted here. 12.5 is a lot better than the original and took about 3 minutes on the lifesaver on my fast PC. The 16.5 version was not noticeably different in look from the 12.5 version and took 15 minutes (probably take over a day to generate a large file).
4.5 passes:
12.5 passes: ![]() Math meets art meets psychedelia. |
| Posted: July 15, 2014 7:20 pm | ||||
Wait how do you have "0.5" of a pass?
The set of operations is 1 iteration, so when you break out it's not an iteration anymore, it's a separate process. So technically you can't have 0.5 or something. |
| Posted: July 16, 2014 5:35 am | ||||
Ah, the last pass is only a high pass with high contrast, no blur. I call that half a pass... the DD filter is a hybrid, a couple of the iterative passes are altered by replacing the high pass with derivatives and replacing the blur with noise on different passes. So strictly speaking, I guess we won't call the public version iterative. You can subtract 2.5 from my numbers for the iterative count since 3 passes are altered.
| Posted: July 16, 2014 7:16 am | ||||
lol I'm extremely picky by the way. You'll notice me drill at some of the most trivial things from time to time.
| Posted: July 16, 2014 7:41 pm | ||||
You picky, ha
| Posted: July 16, 2014 7:48 pm | ||||
i still love much this filter and gives a very good result with this reaction difussion patterns based on the source image, well done
| Posted: July 24, 2016 6:19 pm | ||||
Funny how damn slow this filter is... anytime I do reaction diffusion i use AppleScript to do it in Photoshop. It was an interesting experiment.
| Posted: July 24, 2016 6:52 pm | ||||
It may be slow but this makes something that is not possible as far as I know in Photoshop, and is to make the reaction diffusion FOLLOW THE SHAPE and contour of the source image and that is the real beauty and amazing thing of this filter
Sorry that I have no idea about scripting with AppleScript with Photoshop, but can you really make in AppleScript the same as it happens in this filter where the reaction difusión effect Is created from the source shape AND keeps correctly the contour of it ? Searching for AppleScript effect I found this CNC software reaction diffusion that just found and not tested yet AWESOME AND AMAZING ANIMATED REACTION DIFFUSION IN ADOBE AFTER EFFECTS Alive tool for After effects Reaction Difussion tool And in the behance page you can see even more Alive tool in Behance |
| Posted: April 11, 2022 3:07 am | ||||
Yes, it is possible in Photoshop. I wrote actions in Photoshop CS6 that were called from the AppleScript. However I no longer use Adobe products and don't have the actions anymore. The basic loop is Blur > Highpass > Threshold repeated as much as possible. I am working on a more basic version of this filter, it allows changing the parameters to the 3 components in the reaction diffusion loop. Found some unusual results, I've attached one.
The gmic.eu filter set (used in GIMP, Paint.Net etc) has a color reaction diffusion filter in Testing / Lylejk / Lylejk's Stencil ![]() Math meets art meets psychedelia. |
| Posted: April 12, 2022 12:14 am | ||||
I still think that this is really an awesome and amazing filter.
After so much time, I am ashamed that I have missed a very important thing that I have just seen, and is HOW do you count the iterative passes? I mean that there is not available a setting for the passes to be modified, and inside of the filter there is NO LOOP component, so please, can you be so kind to tell, HOW have you increased the passes to 12.5? It is 3 times the 4 passes plus the final 0.5 pass. Do you multiply the original 4 passes 3 times so it makes 12? But HOW you do it? Thanks very much for your possible help and sorry that I did not notice this before |
| Posted: September 6, 2024 3:40 am | ||||
33,783 Registered Users
+9 new in 7 days!
15,371 Topics
+51 new in year!
23 unregistered users.
