10 Images or Color Stripes Mix V_2.0 Horizontal KALEIDOSCOPE by SpaceRay
http://filterforge.com/filters/11959.html |
| Posted: February 10, 2014 3:07 am | ||
You may think that this is the same as the Vertical one, but surprisingly I found that using horizontal stripes will NOT give the same results and are different and can get hings that is not possible and the same as with the vertical version
INSTRUCTIONS FOR THIS FILTER Here are the full instructions about how to use and get the most out of this setting and explaining better what the different settings do This one does not include the Kaleidoscope controls part settings only the main part that is the same in all the 5 different versions available
THERE ARE AVAILABLE SEVEN VERSIONS OF THIS FILTER Please note that this is not just ONE filter, I have already made other 6 versions of this filter that has different features each one 1 - 10 Images or Color Stripes Mix V_2.0 Basic Vertical This is the easiest and most simple versión and basic features
2 - 10 Images or Color Stripes Mix V_2.0 Vertical This adds some more features, like frames between stripes. Will make stripes mainly in Vertical way
3 - 10 Images or Color Stripes Mix V_2.0 Vertical KALEIDOSCOPE This is the same as the second one but with two Kaleidoscope options fixed and variable and that will give you Kaleidoscopic stripes using vertical stripes or rotated ones.
4 - 10 Images or Color Stripes Mix V_2.0 Horizontal In the Vertical filter you can rotate the stripes to make them horizontal, BUT the problem is that the image inside is ALSO rotated so it will not work for horizontal stripes, so if you want to have that the images are ALSO horizontal you have to use this filter instead
5 - 10 Images or Color Stripes Mix V_2.0 Horizontal KALEIDOSCOPE You may think that this is the same as the Vertical one, but surprisingly I found that using horizontal stripes will NOT give the same results and are different and can get hings that is not possible and the same as with the vertical version
6 - 10 Images or Color Stripes Mix V_2.0 RADIAL Rings Polar This will allow you to have Radial circular distribution of the stripes OR have them as concentric circular rings and with two different polar effects
7 - 10 Images or Color Stripes Mix V_2.0 FULL VERSION The link is yet not available, please see below for the link when it is available, thanks This version will include ALL the above features in ONLY ONE filter although is more complex and difficult to use tan the above simplified versions. |
| Posted: February 10, 2014 3:09 am | ||
14 unregistered users.
