10 Images or Color Stripes Mix V_2.0 Horizontal by SpaceRay
http://filterforge.com/filters/11950.html
In the Vertical filter you can rotate the stripes to make them horizontal, BUT the problem is that the image inside is ALSO rotated so it will not work for horizontal stripes, so if you want to have that the images are ALSO horizontal you have to use this filter instead
INSTRUCTIONS FOR THIS FILTER
Here are the full instructions about how to use and get the most out of this setting and explaining better what the different settings do
This one does not include the Kaleidoscope part only the main part that is the same in all the 5 different versions available
The full text of this is available also in this other thread 10 Images or Color Stripes Mix V_2.0 Vertical
THERE ARE AVAILABLE SEVEN VERSIONS OF THIS FILTER
Please note that this is not just ONE filter, I have already made other 6 versions of this filter that has different features each one
1 - 10 Images or Color Stripes Mix V_2.0 Basic Vertical
This is the easiest and most simple versión and basic features
2 - 10 Images or Color Stripes Mix V_2.0 Vertical
This adds some more features, like frames between stripes. Will make stripes mainly in Vertical way
3 - 10 Images or Color Stripes Mix V_2.0 Vertical KALEIDOSCOPE
This is the same as the second one but with two Kaleidoscope options fixed and variable and that will give you Kaleidoscopic stripes using vertical stripes or rotated ones.
4 - 10 Images or Color Stripes Mix V_2.0 Horizontal
5 - 10 Images or Color Stripes Mix V_2.0 Horizontal KALEIDOSCOPE
The link is yet not available, please see below for the link when it is available, thanks
You may think that this is the same as the Vertical one, but surprisingly I found that using horizontal stripes will NOT give the same results and are different and can get hings that is not possible and the same as with the vertical versión
6 - 10 Images or Color Stripes Mix V_2.0 RADIAL Rings Polar
This will allow you to have Radial circular distribution of the stripes OR have them as concentric circular rings and with two different polar effects
7 - 10 Images or Color Stripes Mix V_2.0 FULL VERSION
This version will include ALL the above features in ONLY ONE filter although is more complex and difficult to use tan the above simplified versions.
13 unregistered users.
