I have seen the new music CD of Madonna called MDNA, and I like much the cover she has used as it breaks and repeats the image in parts and gives a beautiful effect.
I have not seen or found yet any filter in the FF library that could be similar to this. Please if you know one, would be good to put the link here. I have thought about making it, but do not have still much FF knowledge, and do not know how could I do this, but surely this can be done and do not think would be hard to do. I think that it looks like it has some kind of gradient curves to bent the pieces of photos and so they are not flat cut
| Posted: April 16, 2012 5:53 am | ||||
Mongoose King
So a filter to make giant bulging veiny he-man arms look normal?
![]() Release the Mongoose! |
| Posted: April 16, 2012 9:54 am | ||||
If that's the reason for the filter, I must say, it works! |
| Posted: April 16, 2012 3:45 pm | ||||
Making some little investigation I have found a way to do this and is much simpler than I thought, I have started to do it and will develop it more so it is more similar to the above. Look at the example attached below.
This is just a simple one example, now I need to add more variations and that you could change how many lines you want, and also look more like glass panels with some refraction and distortions, and think I know how.
I think you are refering probably to this that can be seen here and here why this happened to her is here, and she is not the only one I do not care at all about this as what is important is the fact of what she does and how she does it and like very much it and none can cast a shadow over her. Also I understand why she must excersise so much because she must do so many concert and shows where she moves much and with 50 years this is a hard thing to do. |
| Posted: April 16, 2012 11:40 pm | ||||
Here is some refraction that I must make better to adjust more to the glass panels |
| Posted: April 17, 2012 1:55 am | ||||
SpaceRay,
First madona link = Eew! Second madona link = EEEEeeeeeewwwwwww! What madona does, amazing! how many other sinders get hit after hit after hit after hit for so many years? Your filter, WOW! That's spot on! You're getting better at this |
| Posted: April 17, 2012 3:28 am | ||||
15,510 Registered Users
+7 new last day!
+58 new last day!
10,191 Topics
+10 new last day!
GMM, 4 unregistered users.
