I have put already in this thread Panography style filter ???? what a panography photo collage is.
And I know that a real panography must be done with LOTS of different photos so it would be impossible to make this in Filter Forge, but there is ALSO the panography technique based on converting ONE single photo into a panography style photo. In the other thread there was some confusion about this, so I decided to make a new thread dedicated ONLY to what is really possible perhaps on filter forge. I have searched for the ONE photo panography style effect to show an example on HOW it would really look and HAVE FOUND IT !!! It is inside the http://www.picnik.com , this is an online web applicattion that have lots of photo filter modifications and effects for your photos. Please to see the real Panography_ish filter make the following 1 - Go to http://www.picnik.com/ NOTICE THAT THIS IS ONLY UNTIL 19 APRIL 2012!!! 2 - Click over "Get started now" 3 - Upload your photo or use one of the demos 4 - Then when it opens, look in the menu above top left, for "effects" tab and click it. 5 - Search in the left side list for the "Panography-ish" filter and click on it 6 - Customize your photo with the sliders For the example shown I have used one of the demo photos included there.
Here is one example I made to show WHAT a ONE single photo Panography looks like using this Panography-ish picnik filter
And changing the kookiness it lets you to ROTATE the squares !! BUT Then for my taste and personal opinion, and although this looks also beautiful and interesting it looses the panography style look and misses the elegant effect. Although I also like much this feature of Kookiness but for using it in some kind of collage that does not need to have the panography look and style. |
| Posted: March 1, 2012 2:11 am | ||||||
The effect you show here:
IS possible with FF, and it's not very complicated. The kookiness example:
Is also possibke, although a little more complicated. |
| Posted: March 1, 2012 9:33 am | ||||||
Well, this is very good news that this would be possible and it´s not very complicated, and really this is the MAIN essential of the Panography One single filter technique. So if is possible to do this would be very good
Well, if this is more complicated, is not really so important, although is also nice, but would be enough with the first part, and then after if it would be possible the second part could be done, OK, but if not I am happy with the first part alone. Thanks very much |
| Posted: March 1, 2012 11:01 am | ||||||
Here's a basic implementation of a single photo panography.
You can set the size of the photos that make the panography, and you can turn photo shadow on/off. This is a very simple filter, and it doesn't let you controll much. For example, you can't control where the photos will be, and you can't set "central zone" where the photos will be denser. Maybe you can improve it and upload it for us all Single Photo Panography.ffxml |
| Posted: March 1, 2012 3:24 pm | ||||||
WOW!! Thanks very much for your really fast filter making, I would have never expected that you will be able to do it in a few hours !!!
I will see and test what you have done and give then later my opinion, and possible questions and/or suggestions Thanks again for your help, your time and your work. |
| Posted: March 1, 2012 5:56 pm | ||||||
33,846 Registered Users
+13 new in 30 days!
+44 new in year!
20 unregistered users.
