KGtheway2B
KGtheway2B
I've been trying to get something that repeats an element a predicable number of times in a radial direction. With some fudging of gradients I can get to the attached image but it's very inaccurate- what I'd like to see in the final product is a perfect circle repeated.
KGtheway2B
KGtheway2B
I did some hunting and the only thing I could find was this one: http://www.filterforge.com/filters/3166.html
This is NOT how I want to do it smile;)
http://img210.imageshack.us/img210/1271/cjhiqe8.jpg
^^Attachments don't seem to work.
KGtheway2B
KGtheway2B
Trying to attach filter.
Didn't seem to work...
yes, attachments seem to be on the fritz right now. not sure why, but i cant attach images on the forums either.
Heres some more to check out and study....
You might find the answer in one of these...
http://www.filterforge.com/filters/5423.html
http://www.filterforge.com/filters/4806.html
http://www.filterforge.com/filters/1555.html
Then a bit more of using the Angle Gradient Snippet..
http://www.filterforge.com/forum/read...0&TID=1987
KGtheway2B
KGtheway2B
Still not having any luck smile:(
Star Attempt 2.ffxml
KGtheway2B
KGtheway2B
While investigating the links you gave me though, I couldn't help but do a litlle mod of leaf by design, take a look and see if you like it
Leaf by Design Vol. 2.ffxml
Cool.. smile:pimp:
Eventually I will do the Vol.2..With different leaf designs...
Hi KG,
This should do it. Made from ByRo/UberZev spherize/unspherize snippets.
Put the element you want to repeat in the horizontal center, in the top half.
TD
Radial repeat.ffxml
KGtheway2B
KGtheway2B
That's freakin brilliant, thanks a bunch. I'll format it a bit and post my early results here, then you should submit it as a snippet.
KGtheway2B
KGtheway2B
Still needs a lot of tweaking, but here's one pass I took with it.
I'll paste the snippet here soon.
KGtheway2B
KGtheway2B
Here's the snippet, ThreeDee, please submit it to the library- I want you to have the credit and I think this is an important snippet! It's all ready to go with presets, it just needs a textual description (you know who to give credit to and whatnot).
Radial Repeat Snippet.ffxml
Hi KG,
Good solution TD smile:)
@KG very cool its like a metal pearl necklace.. smile:)
Very nice, TD! You should definitely submit that one to the library...
*** starts daydreaming about salami slices on pizza, screws and bolts around a porthole, cookies, ... ***
Thanks. I submitted it -- the original version -- as a snippet. I can see some other filter potential in it.
never mind smile:(
Having seen other filter potential in the Radial Tiling one, I made a couple of interesting ones. Coming soon to a Filter Store near you...
Oh shoot, I just realized this will make it possible to do some nice flower-type stuff, too. Gotta give it a try.
KGtheway2B
KGtheway2B
This is so frustrating... I really needed this technique for something all those months ago and now for the LIFE of me I can't remember what it was!
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
70 unregistered users.
