ronviers
lighter/generalist
Would it be possible for ff to designate, specify or otherwise sanction a filter for reference purposes? Render time on this standard filter could be designated as a one and used to rate the performance of our computers. This would allow us to make statements about our filters like; this filter renders in 2 minutes on a machine rated a 3.2.
Sorry if this has been discussed before.
Thanks smile:)
@ronviers
there is a mention of machine specs that FF uses to test filters somewhere here in the forums. it sets the standard for rejecting filters that take too long to render. so, i'd guess that would be your base or reference machine. it was something like a 1 ghz cpu with 1 gig of ram or something like that and i believe the rejection time was anything over 15 minutes to render. i have no idea where that thread is now, but you could try some of those specs as search criteria and maybe find it.
ronviers
lighter/generalist
Thanks Craig, I will look into that.
@ronviers
KGtheway2B
KGtheway2B
I think filterforge would be a great CPU benchmark. It utilizes multiple cores and tends to have very high CPU usage. The developers should certainly consider nesting a "benchmark" feature somewhere in V2.
